586,106 active members*
2,916 visitors online*
Results 1 to 16 of 16
    Sep 2023
    13
    Exclamation 'RS232 OSP700M
    Hi
    Can anyone help me with parameter settings for RS232. I have try (PIP) commando then write X CN0: I get 320 error RS232C not ready.
    Cable is connected like picture
    krg
    Goran G
    Dec 2008
    3109
    Re: 'RS232 OSP700M
    Try...
    PIP >> CN0:, >> WRITE
    this should allow any file to be saved as A.MIN in the control, if your settings (& cable) are correct.
    Aug 2009
    1573
    Re: 'RS232 OSP700M
    ...you have to type the file name also to Punch and double check cable.
    https://www.aggsoft.com/cnc-dnc/okum...a-osp-7000.htm
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Hi again
    So if my file on PC is part2.min i need to write this after CN0: Part2.min write ? How can i make CN0: RS232 ready ?
    Aug 2011
    419
    Re: 'RS232 OSP700M
    Which communication program do you use on the PC side?
    "Imagination is more important than knowledge."
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Hi i use dnd4u
    Mar 2009
    1982
    Re: 'RS232 OSP700M
    dnc4u ?
    Aug 2011
    419
    Re: 'RS232 OSP700M
    All communication settings must be same on PC & OSP side and must give send/start command on pc after sending receive command on osp in the timeout value time
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Quote Originally Posted by kurmay View Post
    Hi this is my settings i parameters
    see picture
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Yes sorry.
    Sep 2023
    13
    Red face Re: 'RS232 OSP700M
    This is my settings
    Attached Thumbnails Attached Thumbnails BIT settings.jpg   Parameter settings.jpg
    Mar 2009
    1982
    Re: 'RS232 OSP700M
    I would try to set bit 1 to 0, which responsible for internal / external ready. All the rest can be as they are.
    But the very first point is to check the cable. Because this "not ready" message is so strange.
    Did you tested the communication via that cable let's say between to PC's with Hercules utility?
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Hi i have try this but no change...I´m not sure if i have right pin connected. If i read manual contact show one type and net show different pin. i Try Hercules utility and port com 3 send correct.
    Aug 2009
    1573
    Re: 'RS232 OSP700M
    ...set Data Bit to 7, Parity to Even, Stop Bit to 1, Flow Control to Xon/Xoff.
    then,
    Sending to the PC Go to the 'Edit/AUX mode', [F3] (PIP), [F2] (Punch), type file name, then [Return] or [Write]
    Reading from the PC Go to the 'Edit/AUX mode', [F3] (PIP), [F1] (Read), [Return] or [Write]
    If, that does not work....double check Comm Port number on PC by Holding down the Windows Key type R ....a Run window should popup then type "devmgmt.msc" Hit OK then look for Com Port List.for the DNC4U device.
    DJ
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Contact in the picture from Okuma MX45. Which hole is No. 1 ? On the internet, the pin configuration is not the same as on the machine for D25.
    Attached Thumbnails Attached Thumbnails RS232 D25 okuma.jpg   RS232 pinout internet.jpg   RS232 D25 manual.jpg
    Sep 2023
    13
    Re: 'RS232 OSP700M
    Thanks i will try later today.
    Sep 2023
    25
    Re: 'RS232 OSP700M
    Do you know how to modify P200 system PLC?
