586,106 active members*
2,879 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Cadet LN8C Lathe
    Jun 2023
    47
    I am trying to run a program on an old lathe, problem is when I run through the program on single block, ding everything step by step, I'm getting "alarm B plus var. limit over axis 2". I am new to machining and am unsure about how to diagnose this problem. If anyone knows the steps to take in this instance and could help me that'd be much appreciated.
    Attached Thumbnails Attached Thumbnails IMG_20230831_071326500.jpg   IMG_20230831_071302335.jpg   IMG_20230831_071308922.jpg   IMG_20230831_071321125.jpg
    Aug 2011
    419
    Re: Okuma Cadet LN8C Lathe
    Your SYSTEM and USER parameters are completely wrong.
    You must set X/Z origin first and then must set stroke limits.
    "Imagination is more important than knowledge."
    Jun 2023
    47
    I thought they might be, thank you for your resopnse. Could you tell me how to set X/Z origins? I think I know how to set the stroke limits.
    Quote Originally Posted by nathanokkema View Post
    Hi, I have the same machine, usually when I get that error it's because of the Z axis zero parameter. So for instance, if the part you are trying to machine, is larger than your Z Zero parameter, you would get that error.
    To fix it, move your turret with the No. 1 tool on to the edge of the material you are going to work on, then go to Zero Set, set your cursor on the Z column, and hit Calculate. DO NOT HIT SET OR DEFINE (I don't know how it would say on your machine, just never hit the first option)
    Try that, it should solve your issue
  1. Okuma Cadet LN8C Lathe
    By nathanokkema in forum Okuma
    Last Post: 07-30-2023, 11:02 PM
  2. Okuma Cadet LN8C Lathe
    By nathanokkema in forum Turning Machines
    Last Post: 06-02-2023, 05:09 PM
  3. Need Help! Okuma Cadet LN8C Lathe
    Last Post: 06-01-2023, 07:40 PM
