587,070 active members*
2,931 visitors online*
Results 1 to 6 of 6
    Aug 2011
    420
    Meaning of PIP
    Hi
    I have a question for experts.
    What is the meaning of PIP on okuma osp systems?
    Thanks for replies
    "Imagination is more important than knowledge."
    Mar 2009
    1982
    Re: Meaning of PIP
    Okuma operating system ( as well as the Okuma CPU ) is related to the CP/M which is predecessor of DOS. CP/M and OSP are utilising different approaches to sector access of disk. Their predecessors are tape sector access based operating systems. The PIP function comes back from the tape operating system and it is universal unidirectional input and output streaming tool for a sequence. Means, not a parallel transfer. Signals flow both directions, the stream flow is one directonal. Due to it's flexibility and growing demand it was later elaborated and used for parallel data exchange as wel ( VAX VMS 730 for instance ) on the later Unix OS. It is only one way for input and output data stream ( including even terminal Display and console terminals ) at that old operating systems except of keyboard input.
    It is not abbreviation in my opinion. In order to use the pip command you need to key in a whole line of commands, operands and parameters. Back then it was the only one command requiring long line input - pipe. By keying in all the operands, options and parameters you create a pipe.
    There was no habit of abbreviations back then. Operating system contained limited set of ( built in ) commands - List, Dir, Cls, Find, Type, Peek, Poke, Pip ... I don't remember more There are no directories ( catalogues ) on the CP/M, Thus OSP is more progressive.
    Piping in Linux is quite different thing and there are many other meaning of PIP abbreviation today, not related to OSP in any manner.
    Aug 2011
    420
    Re: Meaning of PIP
    Thank you for your quick reply.
    I think that's means is Peripheral Interchange Program (PIP)
    Mar 2009
    1982
    Re: Meaning of PIP
    or interface :-)
    Yes, of course it is very likely.
    Apr 2018
    135
    Re: Meaning of PIP
    Back in the stone age, I was a Kaypro Computer service tech.
    And the original Kaypro systems were CP/M based. And yes PIP is a CP/M acronym for "Peripheral Interchange Program". More on CP/M PIP here: https://en.wikipedia.org/wiki/Periph...change_Program
    Aug 2011
    420
    Re: Meaning of PIP
    Okuma says PIP is Peripheral Interface Program
  1. U drill cutting o/size and leaving pip
    By garylb in forum Haas Lathes
    Last Post: 09-21-2012, 08:34 PM
  2. pip programs
    By kjac62 in forum Okuma
    Last Post: 08-26-2011, 12:23 PM
  3. T100M PIP switch
    By WSS in forum Hypertherm Plasma
    Last Post: 03-17-2011, 07:23 AM
  4. Captain L-370 RS-232 PIP question
    By bozlawless in forum Okuma
    Last Post: 12-09-2010, 04:45 PM
  5. pip files
    By steveo in forum Okuma
    Last Post: 07-25-2010, 01:37 AM
