586,080 active members*
3,680 visitors online*
    Jan 2006
    8
    Surface Finish
    I have a 7"x 10" HF mini lathe and I changed my gears for some threading. Now I want to change back to the correct gears for a smooth finish on the OD using the auto feed, but, I don't remember what gears I used. Help...thanks
    If you go to Little Machine Shops site there is a information booklet you can view on the mini lathes. It tells about the change gears and what was stock.
    Jul 2005
    442
    256 TPI - 20,80,20,80
    Aaron
  1. Surface finish
    By skmetal7 in forum Mini Lathe
    Last Post: 09-10-2007, 06:56 PM
  2. Surface finish
    By chakaloso in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2007, 02:54 AM
  3. surface finish
    By fadalman in forum BobCad-Cam
    Last Post: 03-03-2007, 08:30 AM
  4. Surface finish
    By d.a.v.e in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2006, 08:35 PM
  5. 32 surface finish
    By mroy0404 in forum MetalWork Discussion
    Last Post: 05-29-2006, 03:02 AM
