586,512 active members*
3,366 visitors online*
Results 1 to 13 of 13
    Sep 2006
    10
    Can a Laser Cutter cut Fiberglass Mat ?
    Hello,
    Does any one know if a CO2 laser will cut fiberglass mat, and if possible, how much power is required ?
    Jul 2007
    78
    If you mean the fabric, before the resin is done, I would say probably so. I have cut thin, finished fiberglass sheet. It does char some though.
    Sep 2006
    10
    Yes, sorry I do mean the fabric. Any indication of the actual thickness, speed and the power used ?
    Jul 2007
    78
    Quote Originally Posted by fanie View Post
    Sorry, no. It might be similar to felt in density, which I have cut on my 45 watt at speed 60 power 30 frequency 500.
    Sep 2006
    10
    Has anyone else ever cut fiberglass mat with a laser cutter ?
    Sep 2006
    10
    Nobody ever tried to cut fiberglass mat with a laser cutter before ?
    Aug 2003
    494
    If I had some I would give it a go with my 30 watt laser, but I haven't. I will look around for you and see what I can come up with .... be patient.
    Rich
    I am not completely useless.......I can always serve as a BAD example.
    Sep 2006
    10
    Hi Rich, thank you very much... Appreciated !
    Dec 2005
    484
    I am pretty sure you can cut fiberglass mat or cloth with a CO2 laser, as it is just glass fibers and glass absorbs the CO2 laser wavelength very well.
    I have heard that cutting Kevlar with a CO2 laser will give off cyanide gas, so might want to use scissors on that stuff :-)
    Sep 2006
    10
    Many plastics give off poisenous gasses, so it's always better to vacuum it out.
    Nov 2007
    9
    hi, we producr laser engraver, and laser cutter, there is 40w, 50w,60w ,80w and 100w laser tube. I think our machine could do that. If you are interested in, please contact me. My email is [email protected]. Hope i can help you.
    Vikki
    Aug 2003
    494
    Hi Fanie,
    I just scabbed a piece of glass cloth from one of my friends which came out of a fiberglass repair kit and took a lash at cutting it. The piece was about 2 inches wide and 3 inches long.
    I set the 35 watt laser on full power and 0.1" per sec and it cut through very nicely with a minimum amount of sparking or spatter (no spatter really).
    I then set it on 0.2" per sec and it cut through 99% of the fibers. So anywhere between 0.1 and 0.15 would do the trick.
    Hope this helps. Do I need to take a video of it for you? I don't have much time on my hands but I could make it possible.
    A 60 watt laser would just eat through the stuff.
    regards
    Rich.
    Aug 2003
    494
    Youtube video of it here.....
    [ame]http://www.youtube.com/watch?v=3QOa6PSy3BY[/ame]
    I wish I had some woven matting to try for you but alas I have not. It should work roughly the same though.
    Regards
    rich.
  1. Laser Cutter/Engraver
    By jymmm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-31-2010, 06:42 PM
  2. looking for a cheapish laser cutter...
    By UltraMagnus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-27-2007, 06:19 PM
  3. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  4. What laser cutter for classroom use?
    By bbuonomo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2006, 11:42 PM
  5. Laser cutter price?
    By Micro Rotors in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-14-2006, 12:29 AM
