586,116 active members*
3,361 visitors online*
Thread: Sprocketeer
    Jun 2014
    1780
    Sprocketeer
    I found an interesting program on the internet called Sprocketeer, I needed a couple of #25 - 30 tooth sprockets for my welding turntable, I looked on the net and found this program, very simple and quick and outputs a dxf file and g code, the code had errors in it but the dxf loaded into Rhino, finished drawing it up and it worked perfectly! This one is 40 tooth, needed one for show and tell............
    mike sr
    Jun 2014
    1780
    Re: Sprocketeer
    mike sr
    Apr 2011
    720
    Re: Sprocketeer
    Looks like it would be fun to play with, I'm going to give it a try,.
    Thanks Mike
    Jun 2014
    1780
    Re: Sprocketeer
    Quote Originally Posted by MFchief View Post
    Thanks Mike
    It is fun to play with, I have made 4 sprockets #25 chain so far for my turntable (welding rotator), the only thing I had to modify slightly was the .125 endmill diameter to .121 to get a bit more clearance for the rollers.
    mike sr
  1. Updated Sprocketeer progam
    By mgreene in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-18-2008, 04:32 AM
