586,119 active members*
3,645 visitors online*
Results 1 to 3 of 3
    Jan 2018
    22
    water cooled spindle
    I am looking at upgrading my spindle on my cnc. The current is a hitachi router.
    The machine is located in my garage which is not heated or cooled. Location Missouri.
    Can you use RV fluid for the spindle coolent instead of water, or some other coolent that will not freeze in the winter?
    Thanks!
    BG
    Aug 2009
    1573
    Re: water cooled spindle
    ...last resort could use car anti-freeze mix. Anything safe for Alum/Plastics should work..
    DJ
    Nov 2022
    3
    When upgrading the spindle on your CNC machine, it's important to consider the coolant requirements of the new spindle. While using RV fluid or other coolants instead of water is possible in some cases, it ultimately depends on the specifications and recommendations provided by the spindle manufacturer.
    Donkey Kong
  1. Which water mixture to use for water cooled spindle ...
    By evalon in forum DIY CNC Router Table Machines
    Last Post: 05-15-2019, 02:44 PM
  2. Spindle ER11 water cooled VS. ER16 air cooled
    By joaopcrodrigues in forum DIY CNC Router Table Machines
    Last Post: 11-06-2018, 05:47 PM
  3. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
