586,100 active members*
3,137 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > best cad cam for old okumas
Results 1 to 8 of 8
    Jun 2020
    64
    which is the best cadcam? for the old okumas such as the osp5000 lathe, type lb12 lb15, and mc4vae machining center with fourth axis, which has "fixed cycles", as we know these machines do not have large memories..., thanks
    Mar 2009
    1982
    Re: best cad cam for old okumas
    Okuma has it's own product ADMAC.
    Another choice is IGF ( again from Okuma ). All other CAM's suitable which can use arcs and chamfer commands where applicable instead of segmenting shape.
    Aug 2011
    419
    IGF is best choice for okuma
    "Imagination is more important than knowledge."
    Dec 2008
    3109
    Depends on what you want it to make....
    Drill, tap, face, profile simple shapes.... IGF(Admac), any cheap CAM system would output short code files for lathes and mills. I suggest looking at how to create subroutines and other call statements to shorten files.
    3D shapes, complex surfaces etc will always tend to be associated with long code files which don't suit small storage spaces on the older machines.... DNC transfer (not PIP), if you have that option, could allow running big code on short runs.
    DNC is very expensive if added later on these old clunkers, if it is still possible. I'd suggest updating to a newer machine. Better options, faster, current parts, easier connectivity etc
    Ps...IGF is not best choice, it is an option to be added onto the Okuma control, using up more valuable storage space.
    Find something that can be run on a PC, cheap, easy to learn, and makes code for any machine, not just Okuma.
    Mar 2009
    1982
    IGF generates .MIN as well. This could be used on other machines with minor changes.
    In my opinion there is IGF version running on PC as well. ADMAC is a different story it is very much like all other CAM's. While IGF is totaly unique and unbeatable.
    Jun 2003
    205
    KipwareT® (turning) and KipwareM® (milling) ... not CAD/CAM but conversational programming software ... outputs OKUMA code out-of-the-box.
    Check it out here : https://kentechinc.com/kipware-programming-software/
    Jun 2020
    64
    thank you all for the precious advice, for the moment I'm using a cadcan on the computer, I think that as superman said it is the best choice, so I learn to draw and I can create code for any machine, and I must say that it is very fast especially for details with many 3D curves, I don't know if IGF is fast and precise with 3D..
  1. CAD/CAM beginner, which CAD/CAM software to use?
    By burnley1 in forum Uncategorised CAM Discussion
    Last Post: 08-26-2022, 04:45 PM
  2. Accurate CAD | CAD/CAM/CAE Services
    By accuratecad in forum Manufacture Company Listing
    Last Post: 01-02-2017, 11:39 PM
  3. Accurate CAD | CAD/CAM/CAE Services
    Last Post: 12-29-2016, 05:18 PM
  4. BobCAD-CAM Releases New v28 CAD-CAM Software Series
    By aldepoalo in forum BobCad-Cam
    Last Post: 07-16-2015, 01:50 AM
  5. Replies: 0
    Last Post: 03-31-2015, 06:55 PM
