586,075 active members*
3,688 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Power suply FANUC O-T A16B-1212-0100/08A
Results 1 to 6 of 6
    Nov 2021
    25
    Hello!
    Power suply FANUC O-T A16B-1212-0100/08A this power supply starts up later every day.
    Today it started in 5 hours.
    The capacitors look normal
    ON-OFF buttons work
    When turned ON, the red LED lights up.
    As soon as it turns on, it works without errors and you can turn it on and off and the red LED does not light up
    Supply voltage standard 200 volts
    Fuses don't blow
    I'm thinking about how to localize the problem!!!
    Maybe YOU have some ideas!
    Thank you!
    May 2023
    Re: Power suply FANUC O-T A16B-1212-0100/08A
    I would turn the machine on, and start tapping the PCB with an insulated tool, and see if it starts up immediately. I’ve seen broken resistors that would cause failures like this (although not on this specific power supply). Also, if you can get at the back of the PCB, look at all the solder junctions and see if there is any cracking.
    Aug 2009
    1573
    ...do not turn off the control...EStop to disable drives only.
    Nov 2021
    25
    The CNC was not turned off for a week.
    Only the drive was turned off.
    The machine worked without problems.
    On weekends you need to turn everything off.
    And after 20 minutes the power supply did not start.
    On Monday I'll check for cracks and tap with an insulated tool.
    And I will measure
    voltage when turned on at control points.
    Apr 2009
    1379
    You can buy one off Ebay for ~$150 shipped; just replace it.
    Aug 2023
    7
    We have similar problem with A16B-1212-0100/06A power supply. There are lot of secondhand A16B-1212-0100 but /06A is quite rare, can we but some other for example A16B-1212-0100/020A
    Control is Fanuc O-TT and machine is Star KNC-20.
  1. FANUC a16b-1212-0100 diagram
    By matiasjuarez1993 in forum Fanuc
    Last Post: 02-13-2023, 10:04 PM
  2. Problem power unit Fanuc A16B-1212-0110
    By Muha-prev in forum CNC Machine Related Electronics
    Last Post: 10-21-2016, 08:35 AM
  3. Power suply FANUC O-M A16B-1212-0110/03A
    By dh08td in forum Fanuc
    Last Post: 07-16-2016, 04:57 AM
  4. Fanuc A16b-1212-0110 Power supply troubles!
    By Clonekid54 in forum Fanuc
    Last Post: 04-29-2015, 07:06 PM
