I have a Daewoo Doosan lynx 220G cnc lathe with a gang tooling slide and with the live tool option, but can parts be loaded in exactly the same position(on fixture) from part to part, and be drilled on the od or light milled and repeat from part to part to a datum(or driver) on the inside of the part, every time? We want to mill some small shallow slots on the 4” od of parts made from alum and have the position of the slots to repeat from part to part to the id where there is a datum hole running parallel to said slots. If so, what kind of repeatability would we get? Also the chuck can be positioned and “locked” every 5 degrees? If I can do this i can delete a whole op. Also can the orientation position be set in parameters, so each different job can have zero degrees position in a different spot? (can i reset the position to have any part of the chuck be at zero degrees?)
Thanks!
