586,121 active members*
3,184 visitors online*
    Feb 2014
    227
    Calmotion Lancnc
    I have a Calmotion LANCNC-FAD on my FADAL vmc15. I had it setup with a FTP so that I could just drop the file into the machine wirelessly. I do not want to use that FTP anymore. Is it possible to attach a bluetooth adapter with antenna to the ethernet jack and send the files via bluethooth to the machine? If anyone has done this or knowledge of how it would work let me know.
    Oct 2008
    1632
    Re: Calmotion Lancnc
    I was sure you could map a drive in Windows to the IP address of the Calmotion then just drag files over or post directly to that shared folder. I could be mistaken but I think you can. Have you tried it?
    Feb 2014
    227
    Yes you can map the drive and make it work through the FTP but that means you have to use your wifi router. What i want to be able to do is put a bluetooth receiver on the LANCNC board using the ethernet slot and transmit the data or files via bluetooth from my computer direct instead of going through my wifi. Think that can be done? Reason for this is I do not want my laptop hooked up to the internet.
  1. Calmotion USB.
    By neilthib in forum Fadal
    Last Post: 07-02-2020, 12:26 AM
  2. Calmotion A axis fault
    By dougputt in forum Fadal
    Last Post: 02-05-2013, 04:57 PM
  3. Calmotion,Fadal and AlibreCAM
    By masterfabr in forum Fadal
    Last Post: 01-27-2012, 07:33 PM
  4. Calmotion DNC
    Last Post: 02-26-2010, 05:24 AM
