586,075 active members*
4,186 visitors online*
Results 1 to 2 of 2
    Dec 2007
    578
    Probe Routines
    Made some probing routines for mill that might help someone else.Iam sure someone more experienced in c code can clean them up . Be aware i am NOT a c code programmer. More of copy and paste type of programmer.
    I mostly broke down the ProbeMain code in the Probe_JB_Stig folder. Found out that it does not work correctly, or could not get it to work correctly.But i wanted separate c code programs for each probe cycle.And possibly use them with a Mcode function.
    Also added a Z depth to screen so one can control the Z travel. This way you can clear fixturing or part features. Original ccode controlled it by a set parameter within the c code program.
    So far all are working. But i need to check real world accuracy.
    Another thing that is needed is a input in case connection is lost from probe. The touch probe i have does not have another output for this. Thought about hacking it and adding a wire that would know if ground was broke/ cable unplugged.
    Using Kmotion 5.1
    Anyhow, HTH
    Troy
    Attached Files Attached Files
    May 2006
    4045
    Re: Probe Routines
    Hi Troy!
    Thanks much for sharing.
    TK
    http://dynomotion.com
  1. Mach3 Probe routines full auto on rectangles at any angle
    By squirrel_41 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-17-2017, 05:49 AM
  2. Mach3 Probe routines
    By squirrel_41 in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2017, 05:53 AM
  3. Replies: 2
    Last Post: 12-23-2015, 05:52 PM
  4. Perimeter Probe Routines
    By gishere in forum LinuxCNC (formerly EMC2)
    Last Post: 01-12-2015, 06:01 AM
  5. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
