586,270 active members*
3,909 visitors online*
    Simodrive 611u Repair?
    Can anyone here give some good references for a shop to repair a bad Simodrive 611u?
    Preferably in the Midwest (Ohio).
    Mar 2008
    285
    Re: Simodrive 611u Repair?
    Siemens in Mason Ohio is the Drives repair facility for North america
    We have a large CNC router with a 15kw water cooled spindle. The original drive on the machine was a Siemens Simodrive 611u. This is supposedly a very capable drive, but in this application it is/was only being used as an ordinary VFD. The drive failed and now I am trying to discern our best course of action. I know very little about these Simodrives and their abilities.
    I have a quote to repair it for a little less than $5000. I contacted Siemens and because the 611u is considered end of life, they no longer repair them, but will exchange for refurbished unit for about $1000 more.
    That is a lot of money for little more than just a VFD.
    I can buy a new Yaskawa V1000 drive and braking resistor set up for our spindle for about half that much (or maybe less.) Is there any compelling reason to stick with the Simodrive 611u? Or is there some reason that drive is so awesome as to justify it's price premium and I should stick with it vs retrofitting something else?
    (PS our spindle is a 24000rpm 4 pole induction motor with, with no position feedback, so any VFD capable of 800+Hz, 30amp, 400v output could run it. I know the 800Hz requirement does limit options quite a bit, but other wise it isn't exceptional.)
  1. Simodrive 611?
    By Todd Zuercher in forum SIEMENS -> GENERAL
    Last Post: 08-31-2023, 12:52 PM
  2. Technical Repair Solutions (Midwest USA): Industrial Electronic Machine Repair
    By TechnicalRepair in forum Manufacture Company Listing
    Last Post: 11-04-2014, 09:04 PM
  3. Need Help - 840D with 611U Oerlikon Gear Cutting Machine
    By M.RISHIKESH in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-11-2011, 08:02 AM
