586,119 active members*
3,587 visitors online*
    Sep 2023
    Homing/Limits Help
    I had a different issue earlier, and through trying to fix that, u changed the "reversed" and "home neg" selections trying to fix it.
    With whatever I did, the machine is now seeming to move in opposite directions and not working.
    Does anyone know what I have wrong with this window?
    Mar 2015
    410
    Re: Homing/Limits Help
    You can change the direction of the motor in the config | Port & Pins | Motor Outputs screen:
    Invert the Dir LowActive setting.
  1. Homing and Limits... new machine.
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-25-2014, 09:59 PM
  2. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  3. Help!!! I'm New!!! Homing/Limits Problem!!!
    By gagulau in forum Mach Software (ArtSoft software)
    Last Post: 05-04-2013, 08:07 PM
  4. Need Help with homing and limits
    By ratpack in forum Mach Plasma / Laser
    Last Post: 04-28-2010, 05:31 AM
  5. Homing and Limits Setup
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2009, 04:12 AM
