586,121 active members*
3,148 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Sprindle problem with chineese CNC router
    Mar 2016
    9
    Hello
    I have a chineese CNC router with a clone rich auto DSP since 2012( when i bought the machine I was a total newbie and had no idea that there were original and clone parts), it was working fine so far, but today having an issue with the spindle (water cooled) .
    The problem is after powering on the machine the spindle starts turning immediately even at a higher speed that it normally runs. I can't even switch it off with the on/off button on the dsp. Have to shup down the machine for the spindle to stop. The X, Y and Z axes move OK even though the spindle is turning.
    Have not made any changes in the DSP setting. In fact, did not use the machine for a few weeks due to health issues, and getting this problem when switched on the machine.
    Any idea what could be the problem, any suggestions most welcome.
    Thank you.
    Re: Sprindle problem with chineese CNC router
    suggest power on again ,if you will meet same problem. is your dsp 0501 or dsp A11 mode .
    Kindly also check if have alarm code on inverter which it is cabinet inside .
    if button can not work ,maybe need a update system or change new control , video and picture is easy to help engineer find question .+8618560201508
  1. 3040 chineese Cnc with MAch 3 . Need Help please
    By kursad79 in forum Chinese Machines
    Last Post: 07-16-2020, 12:37 AM
  2. Chineese plasma cnc controller
    By medi_neon in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-21-2020, 09:42 AM
  3. chineese 6560 4 axis cnc control board issues
    By Warhawk in forum Stepper Motors / Drives
    Last Post: 02-13-2018, 06:25 PM
  4. Replies: 15
    Last Post: 10-09-2017, 10:49 AM
  5. Sieg SX3/SX3L sprindle control
    By DvG4 in forum Benchtop Machines
    Last Post: 01-14-2011, 04:13 AM
