586,094 active members*
4,071 visitors online*
Results 1 to 6 of 6
    May 2023
    6
    Feed hold problem
    Hello. I have a Hwacheon hi tech 200 with a FANUC OI-TC controller. My question is; The feed stop button does not work. When I press this button, the machine that should stop continues as if nothing happened, and this is annoying.Is this a parametric thing or what is it about?
    Feb 2006
    1792
    Re: Feed hold problem
    Are you doing rigid tapping?
    May 2023
    6
    No, I only do flat turning, but no matter what the process is, the feed stop does not work at all.
    Feb 2006
    1792
    There is no parameter to disable feedhold button.
    Possibly, it is malfunctioning. Did it ever work earlier?
    May 2023
    6
    I don't know if it worked before, I just bought the machine. However, a friend of mine who owns the same machine also complains that the feed hold button does not work. I want to see if there is a problem with the PMC signals but the pmc ladder is encrypted.
    Feb 2006
    1792
    If the same problem is there on similar machines, then possibly this function is not enabled. Contact MTB to find out.
  1. 410PA ALZMETALL Baz 15 Problem it does not enable axes feed HOLD
    By wojtekthx in forum Uncategorised MetalWorking Machines
    Last Post: 07-16-2018, 11:01 PM
  2. Feed Hold problem
    By pit202 in forum Haas Mills
    Last Post: 07-30-2010, 07:53 AM
  3. Feed Hold Problem
    By metx in forum Fanuc
    Last Post: 01-30-2009, 05:10 PM
  4. Feed Hold
    By HelicopterJohn in forum Haas Mills
    Last Post: 04-25-2008, 03:57 AM
  5. Feed hold problem
    By kirby in forum Fanuc
    Last Post: 07-13-2007, 02:33 PM
