586,077 active members*
3,883 visitors online*
Results 1 to 5 of 5
    Jan 2013
    73
    FANUC 0M - 511 Alarm help
    Hi, When I turn on the machine I am getting: 511 Achsendlage : -X (alarm in German)
    Anyone know how to solve this issue?
    Thank you.
    Re: FANUC 0M - 511 Alarm help
    Quote Originally Posted by mlinkadelsol View Post
    Thank you.
    Alarm for stroke check prior to movement.
    The end point specified in a block falls within the forbidden area defined with the stroke check in the negative direction along the X axis.
    Correct the program.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jan 2013
    73
    Quote Originally Posted by cncmakers001 View Post
    Hi still have the same problem. For example if I turn ON the machine and want to do Homing I would need to move the X axis in -X direction to home it with +X. But alarm 511 doesnt let me. I can move the motor in -X direction by hand when the machine is OFF away from the Homing switch and then I can do Homing for all the axes but alarm still stays ON and I am unable to move the machine in -X direction. Machine also has Absolute encoders installed. Any help would be appreciated. Thank you.
    Aug 2009
    1573
    ...faulty Limit switch -X most likely. . Coolant, Oil, Dirty, or Old age Micro switches do not last for ever..
    Good Luck Hunting,
    DJ
    Jan 2013
    73
    Good Luck Hunting,
    DJ
    I solved the problem by changing the parameter for homing for X axis.
  1. Spindle A06B-6059-H206#511
    By Isaias Camacho in forum Fanuc
    Last Post: 12-07-2010, 06:00 PM
  2. Error 511 in Fanuc OM/ Johnford VM1050
    By trrdunhill in forum Fanuc
    Last Post: 08-12-2010, 03:54 PM
  3. Alarm 511 Meldas Mo
    By LnL in forum Uncategorised MetalWorking Machines
    Last Post: 07-11-2007, 09:32 PM
  4. Alarm 511 Meldas Mo
    By LnL in forum DNC Problems and Solutions
    Last Post: 07-11-2007, 04:02 PM
  5. Alarm 511 Meldas Mo
    Last Post: 07-11-2007, 03:40 PM
