Hi, When I turn on the machine I am getting: 511 Achsendlage : -X (alarm in German)
Anyone know how to solve this issue?
Thank you.
Thank you.
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
Hi still have the same problem. For example if I turn ON the machine and want to do Homing I would need to move the X axis in -X direction to home it with +X. But alarm 511 doesnt let me. I can move the motor in -X direction by hand when the machine is OFF away from the Homing switch and then I can do Homing for all the axes but alarm still stays ON and I am unable to move the machine in -X direction. Machine also has Absolute encoders installed. Any help would be appreciated. Thank you.
...faulty Limit switch -X most likely. . Coolant, Oil, Dirty, or Old age Micro switches do not last for ever..
Good Luck Hunting,
DJ
