586,106 active members*
3,134 visitors online*
Thread: X-Zero
Results 1 to 1 of 1
    Jan 2011
    10
    X-Zero
    Hello everyone,
    Its been a little while since I started this build, I have gotten to the point where all the electronics are ready to be installed. Unfortunately due to circumstances I'm unable to move forward with it and have decide to put up for sale. No skimping on parts was ever an option, but the idea was too start off with working with wood and eventually progress to aluminum, hence the choice of the router installed.
    Some of the features are:
    X-Zero frame, T-slot table top, 3/4" aluminum frame makes this an extremely rigid design that will machine aluminum and steel. Reinforced gantry, oversized screws and motors makes this an amazing router. Custom table will support over 2000lbs. All electronics are included but still need to be mounted. Enclosure box , drives, nema 34 adapters, servo motors, relays, hand controller, all power supplies, router motor, sensors included. Machine is located in Whitby Ontario, if interested message me at 416-723-6877.
    Also included is a desktop PC with monitor. Software Installed includes:
    Licensed copy of Windows.
    Mach3.
    Aspire 3.0 with DVD tutorials & Extras.
    Mastercam X5.
    Vcarve Pro.
    2D Cut
    3D Cut
    Photo Carve
    Photos
    Apr 2018
    134
    Re: X-Zero
    At CNCZone the photos above are not viewable due to a server issue, however they are viewable in the post here: https://en.industryarena.com/forum/x-zero--464995.html
