I was wondering if on HMC's is the full 4th axis an option that is turned on thru the control, IE. an option thru FANUC like rigid tap, so if the machine has 1 deg. indexing are you stuck with it as an idexer or can it be coverted to a full 4th rotary? or is something that has to do with the machine itself?
