586,096 active members*
3,613 visitors online*
    Oct 2023
    buffer batteries
    hi, does anyone know where the buffer batteries are on bridgeport vmc 1000xp2 2004, heidenhain i530 control, ive changed them on older vmc's but can find them on this machine, cheers.
    Aug 2009
    1573
    Re: buffer batteries
    ...I would backup everything 1st. Parameters of machine, etc...just in case of loss. When changing battery do it with the machine powered ON is best if, possible.
    DJ
    Apr 2012
    4
    Check inside the computer module. It could be CR2450N (don't use battery without N letter, doesn't fit)
  1. Bridgeport VMC600/22 buffer batteries
    By HugoLargo in forum Bridgeport / Hardinge Mills
    Last Post: 12-04-2018, 03:16 PM
  2. Bridgeport interact buffer batteries
    By jack-pat in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2015, 04:01 PM
  3. Back up batteries
    By MazakMack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-04-2013, 09:50 PM
  4. New Year... New Batteries!
    By behindpropeller in forum Haas Mills
    Last Post: 01-30-2012, 04:51 PM
  5. Batteries
    By underthetire in forum Okuma
    Last Post: 11-10-2011, 09:38 PM
