586,104 active members*
3,317 visitors online*
    CNC: 1202 Z axis hard limit overrun
    when i try to move it down this message appears CNC: 1202 Z axis hard limit overrun fagor 8035 - m
    Re: CNC: 1202 Z axis hard limit overrun
    Quote Originally Posted by Hossammax View Post
    Check the Z axis limit switch, it could be short circuit or broken.
    Try to install a new one to see if the problem solved or not.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Quote Originally Posted by cncmakers001 View Post
    could you please show me a photo of that switch so i can buy a new one?
  1. Limit overrun and following error while Machine is at rest
    By Jim Brown in forum Fagor Automation
    Last Post: 02-03-2018, 03:39 PM
  2. Hermle UWF 1000 Troubles - Stuck on Z-axis Hard Limit Switch
    By Somac in forum Uncategorised MetalWorking Machines
    Last Post: 04-28-2017, 03:04 PM
  3. Replies: 6
    Last Post: 08-14-2016, 09:57 PM
