Originally Posted by
Iguins
Hello, I am trying to run a generic chinese 1325 cnc router and I am having trouble with homing all axis.
The control system is richauto a 11 and the limit sensors are magnetic type ble-18-5f-n1/e
The problem is that most of the time when I home the motors don't stop at the limit sensors. I checked the sensors and a red led turns on as it should when is near the plate. I also tried formatting the Controller and it seemed to work at the beggining but i would have to do it every time I turned on the machine. Now it doesn't work even after formatting the controller. I think that it must be related with the dsp because otherwise it wouldn't have worked after formatting.
The only change i made to the settings was the pulses per mm.
Do you know what could be causing this?
I would greatly appreciate any help, I tried múltiple solutions and it keeps happening.
Thanks in advance
Luc
