586,094 active members*
3,993 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Cnc machine sometimes ignore limit sensors
Results 1 to 3 of 3
    Oct 2023
    Hello, I am trying to run a generic chinese 1325 cnc router and I am having trouble with homing all axis.
    The control system is richauto a 11 and the limit sensors are magnetic type ble-18-5f-n1/e
    The problem is that most of the time when I home the motors don't stop at the limit sensors. I checked the sensors and a red led turns on as it should when is near the plate. I also tried formatting the Controller and it seemed to work at the beggining but i would have to do it every time I turned on the machine. Now it doesn't work even after formatting the controller. I think that it must be related with the dsp because otherwise it wouldn't have worked after formatting.
    The only change i made to the settings was the pulses per mm.
    Do you know what could be causing this?
    I would greatly appreciate any help, I tried múltiple solutions and it keeps happening.
    Thanks in advance
    Luc
    Jun 2005
    1730
    Re: Cnc machine sometimes ignore limit sensors
    Quote Originally Posted by Iguins View Post
    Thanks in advance
    Luc
    Just because the LEDs blink when activated on each limit does not mean the output transistor in the sensor is working. Look for a input/output test page and ensure the inputs are actually switching
    Oct 2023
    Quote Originally Posted by CNCMAN172 View Post
    thank you for your quick response, do you mean to look into the input check Option in richauto machine settings?
  1. Homing to limit sensors
    By Driller2 in forum PlanetCNC
    Last Post: 10-21-2022, 04:04 AM
  2. Replies: 4
    Last Post: 04-14-2021, 01:56 AM
  3. using NPN inductive sensors for Limit
    By ScorpionTDL in forum PlanetCNC
    Last Post: 10-13-2020, 10:55 AM
  4. CHNC-I limit sensors
    By jmelson in forum Hardinge Lathes
    Last Post: 09-25-2018, 09:15 PM
  5. optical slot limit sensors
    By travis_farmer in forum DIY CNC Router Table Machines
    Last Post: 05-01-2017, 01:23 PM
