587,040 active members*
2,831 visitors online*
Page 3 of 6 12345
Results 41 to 60 of 106
  1. #41
    Sep 2009
    152
    Re: MD001 cnc conversion
    I’m going to use the cast iron I cut out of base for ball screw bracket to fill hole left from crank removal.
  2. #42
    Sep 2009
    152
    Center bracket is going to have to go. It will interfere with ball-screw bracket.
  3. #43
    Sep 2009
    152
    I don’t feel comfortable taking bracket out with out adding a bracket for support. I saw on another post where he put support on the outside of the column. I really liked that idea.
  4. #44
    Sep 2009
    152
    I’m not going to cut brace out of solid piece. There’s nothing square on casting so I going to weld pieces together.
  5. #45
    Sep 2006
    509
    You probably don't need the external support. The issue is that with the dovetail slides the weight of the head tries to pinch the 2 sides together. With linear guides that pinching force just isn't there.
  6. #46
    Sep 2009
    152
    I’m sure you are right but my gut feelings are that most of my machining will be done in this area and I don’t want that to be the weakest point of the column. But I’m not an engineer so I could be overly thinking this. And I would rather do it now versus later after it’s finished.
  7. #47
    Dec 2023
    Direct Macro, since its commencement in 2018, has swiftly ascended to a distinguished position within the realm of computer accessories. Operating as an e-commerce enterprise, we extend our 686759 services to tech enthusiasts who seek nothing short of top-of-the-line peripherals, cables, components, and a wide array of additional products. Our unwavering commitment to presenting a well-rounded assortment of products, coupled with our exceptional customer service and competitive pricing, has securely entrenched our status as the preferred choice for those individuals dedicated to enhancing their computing experience. At Direct Macro, you'll have the opportunity to explore a rich trove of the most exceptional computer accessories available.
  8. #48
    Sep 2009
    152
    I’m going to mock up my table bearing mount to base bearing mount to see how ball screws are going to work.
  9. #49
    Sep 2009
    152
    I was going to weld plates together but they are too thick and I would have to put a lot of heat when welding. I’m trying to keep them as flat as possible.
  10. #50
    Sep 2009
    152
    Finished welding column brace. Don't know it will help but it's done.
  11. #51
    Sep 2009
    152
    After tack welding 2 plates together I bolted and put dowel pins in to keep from shifting.
  12. #52
    Sep 2009
    152
    Ordered some delrin rod to make caps for cap screws. They seem to work fine.
  13. #53
    Jan 2010
    294
    Nice work so far.
    So am I seeing the Y axis as a belt drive behind the column?
    www.steelplinkers.com
  14. #54
    Sep 2009
    152
    Yes, I won’t have room in my enclosure for motor to mount straight out the back. Servo’s are 5000 rpm’s with 5mm ball screw so I need to gear them down.
  15. #55
    Sep 2009
    152
    Getting my column ready for paint.
  16. #56
    Sep 2009
    152
    I tested positive for Covid. So I’m am down for a while. My sons company decided to get rid of some I beams. I’ve been wanting to make a hoist for my mill so now I’m going to make an electric winch. Everything that goes on or used in my mill is just too darn heavy.
  17. #57
    Jan 2010
    294
    Good luck with the Illness- hopefully it’s minor.
  18. #58
    Apr 2007
    1955
    Your build is looking really good.
    Similar to you, we have had something go through the house, but it tests negative to everything so I guess it is just in our imagination.
  19. #59
    Sep 2009
    152
    It felt more like flue than Covid. Gave it to my wife which made the war department happy. I’m feeling a lot better now so I can get back to working on mill. Thanks for your comments they’re greatly appreciated.
  20. #60
    Sep 2009
    152
    Got some paint on column. I’m going to use the larger servo on z axis's since it has lower rpm and a brake and I can direct couple it to eliminate gears and belt.
Page 3 of 6 12345
  1. MTW MD001 CNC Conversion
    By vertcnc in forum Benchtop Machines
    Last Post: 02-09-2018, 01:31 AM
  2. Dave's MD001 CNC conversion
    By dave111 in forum Benchtop Machines
    Last Post: 03-13-2015, 04:30 AM
  3. Austin's MD001 / IH clone CNC conversion build
    By BrownDesert in forum Benchtop Machines
    Last Post: 06-24-2014, 01:22 PM
  4. New MTW MD001
    By Redgoatfab in forum Benchtop Machines
    Last Post: 03-02-2012, 04:36 PM
  5. MD001 gibs
    By yooooda in forum Benchtop Machines
    Last Post: 03-02-2012, 05:48 AM
