Originally Posted by
joeavaerage
It is not true. If fixed gantry were stiffer than other designs for the same amount of material the EVERY machine would be built that way....but there is no one perfect design or layout.
Every design and layout can be made as stiff as any other, all it requires is enough material with enough cross section in the right places. It may be that one design has an advantage over another by your
choice of material or construction method.
Many criticize a column design....its not as stiff as....design 'x' or design 'y' or whatever design is popular today. That is complete rubbish, a column design can be as stiff as any other....if you
design it that way. It will certainly require a column of large dimensions to achieve that stiffness, and you might decide you can do better by using a different design...so go right ahead.
I chose a column design because it gave me the best flexibility (and I don't mean wobbly) to design and build a machine that suited the materials I intended to use and the techniques I could use.
If you choose to use granite then you would probably choose either a fixed gantry/moving table design or a moving gantry design. Both have advantages and disadvantages, but both are identical stiffness wise if
you design them so.
Craig
