587,067 active members*
3,616 visitors online*
Results 1 to 1 of 1
    Oct 2023
    Export tracking on Fanuc 31i.
    Hello everyone,
    I use CNCs equipped with Fanuc 31i, 310is and equivalents. I am looking to develop a sort of tracker in my programs to record production parameters.
    In order to develop this at a lower cost, we started by trying using recordings during the program on #6xx variables, then exporting the data at the end of machining with the DPRINT functions on amovible cart.
    We output timer data, by tools, but I would prefer to replace them with more precise values, but I cannot find the corresponding #system
    Are there variables in the CNC that directly return the values of spindle load, axis load, real spindle rotation, real feed rate, etc.
    I saw that #4109 and #4119 return the values S and F, but are they only the program values or the real values ?
    Feed potentiometer
    Thank you for your help !
    Jun 2015
    4156
    Re: Export tracking on Fanuc 31i.
    hy there are 2 things to consider : frequnecy at which you gather data, and reaction
    low frequency, like seconds, etc is like a timestamp, you can check cycle time consistency
    0.1seconds is for code variants consitency, going for improvements
    0.01seconds is for controler stuff, like different set of parameters, without chainging the code
    <1/1000 is live servo data
    reaction is if you decide something and implement from outside, or build inner logic within the machine program
    for cycle time consistency, you should simply at 1st be sure that your programs are stable at 100% override; once stability is achieved, decide your next move
    i am not a fanuc guy, so i can't provide specific controller advice
    yet i can do such things on okuma ... spindle rotation and feed consistency can be checked by cycle time analysis; some programers preffer to disable input from potentiometers, as to be sure that the operators won't use the override ...
    loads, promising as they are, are much more tricky and chalenging; at 1st you should scan for peaks, to avoid axis shocks, thus ensure smooth motion ... once all ok, develop futher / kindly
    Apr 2008
    12
    Hi Alex...
    We do a lot of DNC & MDC (machine monitoring) for CNC controls, and so I would suggest you use the Fanuc FOCAS protocol. It is standard in your Fanuc 31i control. It runs over port 8193 and uses the Fanuc Embedded Ethernet port. I would suggest getting the Fanuc FOCAS libraries, and rolling what you need - an HMI style dashboard with data logging. Here's a link to our Nexas Networks Dropbox of all the data points that FOCAS can deliver - https://www.dropbox.com/scl/fi/7w0yu...gq583qs89&dl=0 - see for yourself. I connect FOCAS every week using our Excellerant software and know it is a great feature for what you need. Cheers, Tom Gaasenbeek, Nexas Networks Inc
    Dec 2009
    967
    The Fanuc MT-LINKi software it gives all the info you need
