586,430 active members*
3,859 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree journeyman 325 spindle encoder?
    Feb 2016
    115
    Has anyone added a spindle encoder to their J325 for ridged tapping and spindle orientation? I have the actual source code/logic programming manual for the delta 20 Lathe control but it's basically the same as the mill if anything would need to be added into the parameters
    Aug 2009
    1573
    Re: Tree journeyman 325 spindle encoder?
    ...I think the Delta20 control still has support from Dynapath. https://www.dynapath.com/services-faq6.php The bad news is the Ridge Tap was an Option that you have to purchase from them and there is no way around it with a hack from what I learned in the pass.
    DJ
  1. Tree journeyman 325
    By KEVINSTJ in forum Tree
    Last Post: 01-12-2016, 07:16 PM
  2. help tree journeyman 325
    By cnc beginner in forum Tree
    Last Post: 03-05-2014, 07:13 AM
  3. Replies: 5
    Last Post: 04-08-2012, 09:11 PM
  4. Journeyman 325 tree
    By ramsey321 in forum Tree
    Last Post: 09-12-2010, 11:05 PM
  5. Journeyman 325 Tree
    By dalesails in forum Tree
    Last Post: 08-31-2007, 11:54 PM
