587,072 active members*
2,885 visitors online*
    May 2018
    4PS Presision & Speed
    This might be a long shot but does anyone have any idea of the specs/ possible replacement for this stepper motor?
    4PS Precision & Speed
    PST342-1A8
    Current 7.5 Amp
    Voltage 1.73 Volt
    1.8 Deg per step
    What type of stepper is this considered?
    • Permanent Magnet Stepper
    • Variable Reluctance Stepper
    • Hybrid Synchronous Stepper
    I found an old listing for the company but there number is out of service.
    Dec 2012
    203
    Re: 4PS Presision & Speed
    this looks like a "normal" stepper motor. Stepper motors have permanent magnets.
    does t have 4 wires then look at the size and find a motor the same size if possible the lowest inductance ( for speed )
    If you can find one the same current I would just replace it. Otherwise you have to adjust the current in the driver.
  1. First Plasma Build - Older presision plasma linear v rail
    By nharvey in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-03-2017, 09:19 PM
  2. Speed & feed THEN
    By riche543 in forum Calibration / Measurement
    Last Post: 12-16-2011, 12:29 PM
  3. Speed & Feed
    By kal_pesh in forum Mastercam
    Last Post: 02-23-2008, 08:19 PM
  4. Speed & Feed
    By kal_pesh in forum Uncategorised CAM Discussion
    Last Post: 02-21-2008, 05:15 AM
  5. q about mini presision lathe
    By eaven in forum Mini Lathe
    Last Post: 07-31-2005, 04:37 PM
