586,082 active members*
3,733 visitors online*
Results 1 to 1 of 1
    Nov 2021
    19
    Xpro V5 Need Help
    So I have my cnc wired up to test out of the controller which is the Xpro V5. I cant get any motion from any axis' when i try to jog it in CNCjs or Openbuild Control. Im brand new to this cnc world and Im over my head. I thought I downloaded all the right files to make the machine work but idk..
    Here are my components so far
    Bosch 1617 Router
    Xpro V5
    4 23 Nema High Torque Motors (4.2amps)
    24v Power Supply
    NC E-Stop
    4 Limit Switched currently in the NO configuration (I wanted to NC but someone said I need to do something to the software to change it from factory)
    Shielded wire for stepper motors as well as limit switches( Where should I put the drain copper wire?)
    Now it might simply be the motors are to high in amperage for this controller, but still I should see some movement. I downloaded FLuidNC and I think that might be making it worse for me to wrap my head around all of this.
    I just want to start from the beginning and do this right so If you can help me that would be awesome.
    Attached Thumbnails Attached Thumbnails 399928772_10160845325000202_7466179299152732112_n.jpg   399909742_10160845325185202_2334820456055535098_n.jpg   400328938_10160845325135202_941924183049866432_n.jpg   400386954_10160845325085202_1544119392979369187_n.jpg
