586,103 active members*
3,746 visitors online*
    Dec 2016
    24
    Post Wiring Diagram check - CNC BUILD
    Hello everyone,
    I finished my wiring diagram! It would be nice if someone could have a look at it and let me know what they think ? Any suggestions or wrong components choice?
    A big thanks for your help.
    Setup:
    3 x Servo amplifier MR-J4-70B (0,75 kW)
    A Spindle motor 380V 3.7A 50Hz
    Some questions that I have:
    Is it necessary to add an EMI filter before the amplifier?
    Should I use a delay between each amplifier when the circuit is switch on?
    Thanks again.
    Aug 2004
    780
    Re: Wiring Diagram check - CNC BUILD
    I dunno .. but ..
    you have the estop going to the spindle only.
    I suggest adding estop to either hold / disable the servo drives,
    or optionally depower the servo drives, depending.
    Nov 2012
    367
    Couple things... First, it seems odd that you apparently don't have a spindle speed controller in your diagram. Are you really just going direct from the relay to the spindle motor? It is odd in another way too... You couldn't even jog your axis without the spindle being running which introduces all sorts of safety considerations. Therefore, my strong suspicion is that you are showing the relay to the drive. If that is the case, you might want to look at the drive more carefully. I'm not really sure exactly where that relay would be in the power chain, but you never want to put a relay between the controller and a spindle motor. VFDs do not like having heaters or relays after the drive. Your schematic implies that isn't the case, but given that the controller isn't even shown I thought it prudent to comment anyhow.
    In addition to that, I'd look at the spindle controller (if any) and the servo amps a little more carefully too. Your estop paradigm is to kill power to the units. This isn't how the earlier Meldas equipment work. In this case, I'm talking about the M3xx generation because that is all I'm familiar with, but I suspect the later stuff is the same. In those cases, the drives have power applied to them all the time but the the bridge that powers the DC bus has a relay in the circuit. That relay is energized only when the control provides the correct signals *and* when the estop terminals are bridged. I suspect that your later generation MR drive is probably the same.
  1. Check My Wiring Diagram
    By cspearsall1 in forum SmoothStepper Motion Control
    Last Post: 11-01-2023, 09:50 PM
  2. Wiring Diagram for a Nema34 CNC Router
    By 3D-Designz in forum DIY CNC Router Table Machines
    Last Post: 10-04-2020, 05:57 PM
  3. Colchester 2000 CNC wiring diagram
    By Rathousekid in forum Machinery Manuals / Brochures
    Last Post: 04-26-2018, 09:47 AM
  4. CNC plasma table wiring diagram
    By hector-xj in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-16-2016, 04:40 PM
  5. help with wiring diagram for C6 CNC
    By JDsto in forum Syil Products
    Last Post: 01-10-2008, 01:37 AM
