If I am milling a bunch of small 2" x 2" rectangular blocks from a 12" x 24" x.5" plate I can mill one side and then flip it over to complete the milling. I will also do the same for 2" circles. How I hold individual pieces when I flip the plate over? I thought maybe I need some sort of a female subplate attached to a vacuum system, but that seems like a expensive option and I don't know if that will work. Any other suggestions?
I probably should ask in the work holding forum, but this forum seems to have higher traffic and parts will be milled on a Haas. . . . for those that also reads practicalmachinist forums. . . my apologies. . it's the same post.
If I understand you your trying do something like what I have below, see attached jpg. These tabs are .250 ± .001 thick. I needed 32 of them so I cut them .26 deep into .375 stock. I took the milled pc to the bandsaw and cut the surrounding unmilled material away and then seperated them lengthwise and cut those in half ending up with 4 pieces of four. I then face milled the sections of 4 to dimension and deburred them.
For the circles a set of vise softjaws cut to hold the circles would do the same thing, or if you can turn them in a lathe, part them off long. Turn a small step almost deep enough to hold the finished part in a set of softjaws and then face the parts to the finish length. I have a poultry plant that orders 1.750 OD, .501 ID, washers .625 thick. These require a pretty fine surface finish but it was also quick.
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
Thanks for the suggestion, but I don't have a bandsaw. . . I got a suggestion from another forum to drill clearance holes on when I mill the top side so I can access the clamps after I flip the plate over. I'll give that a try . . . if doesn't work I'll look into getting band saw. . . I think the process will go faster if I can maximize the number of squares/circles milled at one time. . . but then again I may only end up milling a few dozen pieces. . .
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
