586,111 active members*
3,293 visitors online*
    Jun 2013
    443
    Need a bit od help to polish my macro please.
    Totally new to me anything in a macro thats more than just a few commands. Ive managed to get this one together but it will be full of mistakes. I have been on this for a while now and its time to ask. Aim is to have a M10 and M11 for a hydraulic brake on a 4th Axis I have built. All it needs to do is:
    M10
    Switch on hyd pump
    Make sure the "brake off" solenoid is closed or close it if its open
    Open the "brake on" solenoid
    Wait for an input (NO signal) closed on brake extension.
    Close "brake on" solenoid
    Turn off hyd pump.
    M11 will be the same but with the IOs swapped around. I managed to get a macro without the inputs working. But only if the "Brake Off" button on my screen is toggled. I guess someone familia with LUA will say - "thats where you went wrong" Hey anyways would someone please give me some advice on how to change this macro to function as it should?
    If I can get this working, I would also like to add in a section that checks pump pressure prior to proceeding. And if there is no pressure, via another input, an error comes up. I think I know what I need to code for this, I just want to get the basic version working. Would appreciate some help please. I can build things, coding is not my strength. To be brutally honest I have no idea what half of my code does. Well, the hSig thing for a start.
    function m10()
    local inst = mc.mcGetInstance() -- Get Mach 4 Instance
    local hSig, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT4) -- Set the handle for output4 pump on output
    local state, rc = mc.mcSignalGetState(hSig) -- Set the state of the handle
    if state == 0 then -- Not sure why but this seems to work to make sure the pump is on.
    mc.mcSignalSetState(hSig, 1) -- Set the pump on
    else
    mc.mcSignalSetState(hSig, 1) -- Regardless of state make sure the pump is on.
    end
    local hSig6, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT6) -- Set the handle for Output 6 which is the brake release solenoid
    local state6, rc = mc.mcSignalGetState(hSig6) -- State
    if state6 == 1 then
    mc.mcSignalSetState(hSig6, 0) -- Ensure the solenoid is closed or the brake wont work
    else
    mc.mcSignalSetState(hSig6, 0) -- Again
    end
    local hSig2, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT5) -- Set the handle for output 5 which is the brake on solenoid. On = open
    local state2, rc = mc.mcSignalGetState(hSig2) -- State
    if state2 == 0 then
    mc.mcSignalSetState(hSig2, 1) --If its off set it on.
    end
    local hSig3, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT4) -- Set the handle for input 4 which is the brake on micro switch. Made = brake on.
    local state3, rc = mc.mcSignalGetState(hSig3)
    if state3 == 1 then
    mc.mcSignalSetState(hSig2, 0) -- Close the brake on solenoid which will lock the brake.
    mc.mcSignalSetState(hSig, 0) -- Turn the pump off
    end
    end
    Jun 2013
    443
    Re: Need a bit od help to polish my macro please.
    Ok well I sorted it anyway. Not sure why it wouldn't work, and now it does. Code below for anyone although I am pretty new to this so whilst it might work for me, it might not for someone else. Also to note the M10 needs a couple of the outputs changed and then its a M11.
    My next step now the basic version is working is to add in some safety locks and parameters like HYD Pressure Alarm etc.
    function m10()
    local hSig1, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT5) -- Set the handle for output5 brake on solenoid
    local hSig2, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT6) -- Set the handle for output6 brake release solenoid
    -- Check if signal handles were obtained successfully
    if not hSig or not hSig1 or not hSig2 then
    mc.mcCntlSetLastError(inst, "There was a handle error")
    return
    end
    -- Set initial states
    mc.mcSignalSetState(hSig1, 1)
    rc = mc.mcSignalWait(inst, mc.ISIG_INPUT4, 1, 5) --Wait 5 seconds for input 21 to become active
    if (rc~= 0) then --Check our return call
    mc.mcCntlSetLastError(inst, "There was a brake error")
    else
    mc.mcSignalSetState(hSig1, 0)
    end
    if mc.mcInEditor() == 1 then
    m10()
    end
    end
    Nov 2013
    4376
    yes that last lot of code looks very much better. In particular you have to be very careful with Lua that a variable remains 'in scope'.
    For instance your local variables hSig, hSig1 and hSig2 must remain in scope throughout the function so that they can be used near the end of the function.
    I still get confused about the rules of when a local variable is in scope and so I make it a rule to EVERY time I need a memory handle I explicitly get it just prior to use,
    it results in fewer issues.
    You are also right to test the intermediate results and offer some sort of error signaling.
    Craig
  1. Replies: 11
    Last Post: 02-13-2018, 03:08 PM
  2. Methods to polish Delrin?
    By originator in forum Glass, Plastic and Stone
    Last Post: 04-26-2009, 06:12 PM
  3. Anyone know how to polish the acrylic or any machine can do that
    By supremeindex in forum Glass, Plastic and Stone
    Last Post: 02-06-2009, 05:57 PM
  4. How does electro-polish work?
    By BLAMM!! in forum MetalWork Discussion
    Last Post: 03-06-2007, 05:11 AM
  5. How do i polish aluminum?
    By touser in forum MetalWork Discussion
    Last Post: 02-01-2006, 02:50 PM
