586,075 active members*
4,063 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Urgent help needed, PLEASE Fanuc 21i Model A
Results 1 to 13 of 13
    Nov 2023
    6
    I've searched everywhere and have been unable to find a solution to this,.
    I began with the problem of being unable to delete a program. On the advice from a different thread, I held down "Reset" and "Delete" while powering it on.
    Now I've got a boatload of errors and none of the mode buttons work as well as the green "Ready" button.
    I've attached a pic of the screen for reference.
    Thank you in advance
    Dec 2009
    953
    Re: Urgent help needed, PLEASE Fanuc 21i Model A
    with RESET+DELETE you wiped out all the parameters and programs form your machine
    now you need the back up to put back in ,if you have
    good luck
    Aug 2009
    1573
    ...when you find your MTB backup file of Param's here is how to get them into the controller.
    https://www.cnc1.com/hubfs/fanuc-lib....pdf?hsLang=en
    good hunting,
    DJ
    Apr 2009
    1379
    If you have a SRAM backup, use that to restore your data.
    Nov 2023
    6
    Thanks everyone for the quick responses.
    I found the backup on the computer. I inherited this, so I'm not sure how it got there.
    I've got two RS-232 ports on the board in the back of the machine. We've been sending programs over one of them. There is a PCMCIA slot, but I've been unable to get it to work.
    Aside from entering it all manually, what's my best option for restoring the data?
    Does that second serial port do anything beneficial?
    Edit : I read in another thread that I should be able to restore it via the RS232, that it works the same as the PCMCIA slot.
    What steps do I take accomplish this?
    Aug 2009
    1573
    you're luck the backup Params were handy...
    ...click this Link and read thru it a few times.
    Manually entry the Param's for RS232 Port or Memory Card settings by hand ...then you can use the Port (hopefully).
    DJ
    Nov 2023
    6
    - - - Updated - - -
    Quote Originally Posted by machinehop5 View Post
    DJ
    Thank you. I downloaded this earlier this morning from your first reply
    My params for RS232 port & interface are as follows:
    N00000 P 00001010
    N00020 P 0
    N00100 P 10100000
    N00101 P 10000001
    N00102 P 0
    N00103 P 10
    N00110 P 00000000
    N00111 P 00000000
    N00112 P 1
    N00113 P 11
    N00121 P 00000000
    N00122 P 2
    N00123 P 11
    N00131 P 00000000
    N00132 P 2
    N00133 P 12
    I'm unable to get to the ALL IO screen. None of the Mode buttons work. I'm still unclear on how to send these DAT files to the Fanuc anyways.
    Apr 2009
    1379
    Is your ladder running?
    Nov 2023
    6
    Quote Originally Posted by memoryman View Post
    ER07 NO OPTION (LADDER STEP)
    Apr 2009
    1379
    You will have lost your PMC parameters; they have to be restored. There may be other issues.
    Nov 2023
    6
    Quote Originally Posted by 8ig_Dave View Post
    Update:
    I've manually entered in the parameters for the 9000s and got some new alarms.
    Mode buttons still not working.
    Nov 2023
    6
    The ladder is running now. MDI is lit but still unable to select any others.
    I'm following the book to input PMC parameters, but I get stuck at step 10. I don't have an FDCAS to read from. My only other options are M-CARD, F-ROM & HOST.
    Aug 2009
    1573
    ...try this for RS232 settings
    P20=3
    P101=10001001
    P102=4
    Also, try using a 3 (serial comm broad) instead of 1 in Step 9 of 6.2.9 Inputting PMC Pars
    ...Remember you have to shut off and restart the Controller after changing Param's to take affect.
    Good Luck,
    DJ
  1. Fanuc Robocut U-V Urgent help needed !!
    By George123 in forum Fanuc
    Last Post: 02-16-2011, 05:00 PM
  2. Daewoo 200b/Fanuc 21i-T Model A
    By nick323 in forum Daewoo/Doosan
    Last Post: 03-02-2010, 07:38 PM
  3. grafic feature on fanuc -21i-model b
    By damon1313 in forum Fanuc
    Last Post: 02-07-2008, 09:36 AM
  4. Does anyone have a Parameter Manual for Fanuc 21i Model A
    By Eagle View in forum MetalWork Discussion
    Last Post: 01-25-2008, 10:52 PM
  5. FANUC 21i help needed
    By rickst in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2007, 01:26 AM
