586,119 active members*
3,532 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Setting Tool Offsets – Will My Approach Work on Fanuc 18M?
    Aug 2012
    71
    Hey everyone,
    I've been setting tool offsets by touching off all tools on the table and inputting the distance from the table to part Z zero in the work offset. It's been my go-to method, and it has worked well for me.
    Now, I'm dealing with a Fanuc 18M control, and I'm wondering if this approach can be applied here. Can anyone confirm if this method can be used on the Fanuc 18M, or is there a different process I should follow?
    Your insights would be much appreciated!
    Thanks a bunch!
    FMJ
    Jun 2015
    4154
    Re: Setting Tool Offsets – Will My Approach Work on Fanuc 18M?
    hi, i am not a fanuc guy, but simply initialize 2 tools with different lenght, then init wcs, call them and check position
    is that easy
    2 different machines can use same method, as long as their axis and directions are identical; on okuma vmc, z axis is + towards up, and z offset is + towards down / kindly
  1. Replies: 2
    Last Post: 07-04-2022, 08:48 AM
  2. Setting work offsets
    By MarioMP in forum Milltronics
    Last Post: 09-23-2020, 11:51 PM
  3. Rapid Turn: Setting work and tool offsets (again!)
    By Fortune7 in forum Tormach Personal CNC Mill
    Last Post: 03-25-2017, 07:12 AM
  4. Setting Tool and Work Offsets
    By Donkey Hotey in forum Haas Lathes
    Last Post: 06-11-2015, 06:40 AM
  5. Setting Work & Tool offsets
    By Shizzlemah in forum Fadal
    Last Post: 04-16-2005, 06:04 PM
