586,103 active members*
3,813 visitors online*
    Jan 2010
    294
    Mach 3 and tool offsets
    How do you (personally) use tool offsets in Mach 3?
    I've been just touching off each tool, and wanted to try using offsets.
    I measured all my tools+holders from tip to the spindle face (Tormach tts holders), and then zero'ed my spindle face on a 123 block. I subtracted the 3in from the block to get zero.
    This works, but it seems overly complicated.
    Is there a better way?
    www.steelplinkers.com
    Jan 2010
    294
    Re: Mach 3 and tool offsets
    Well I think I figured out my issue,
    I was trying to turn off tool offsets on the Mach 3 offsets page, but my code was running a g43 that apparently turns it back on. I also found I had zeroed my spindle a time or two with an active tool offset.
    Seems if I change a drillbit in a chuck that has the same tool number/offset, I just touch it off and update the tool offset and all is good.
    Jul 2022
    22
    Yes took a bit to wrap my brain around on mach4, be nice if the offset would apply when a different tool # is entered in the program run screen instead of having to go and cycle the toggle height in offsets
  1. Mach 3 not loading tool offsets
    By Aerojunkie in forum Avid CNC
    Last Post: 05-05-2019, 06:20 PM
  2. Mach 3, Sub probram , offsets ??
    By Biggermens in forum Mach Mill
    Last Post: 11-18-2018, 10:52 PM
  3. Fauna 21T tool offsets and work offsets
    By tar356 in forum Fanuc
    Last Post: 09-22-2017, 12:44 PM
  4. Replies: 2
    Last Post: 10-24-2014, 04:17 PM
  5. Tool offsets with Mach 3
    By TPPJR in forum OneCNC
    Last Post: 02-27-2006, 05:06 AM
