586,106 active members*
2,879 visitors online*
    Nov 2023
    Exclamation Problems with cutting in corners
    Hello guys, i am new in this!
    I have some used co2 laser 130W and have problems with cutting in corners.
    In the middle of the bed everything is pretty good.
    On my left corner its doing me a double line one is through and other is some small lines and dots.
    On my right side its burning through materia but not enought to cut it.
    I will post some picturs here.
    And please help me!
    Attached Thumbnails Attached Thumbnails 20231117_121249.jpg   20231117_121351.jpg   20231117_121454.jpg   20231117_121606.jpg
    20231117_121709.jpg   20231117_121818.jpg   20231117_121925.jpg   20231117_124422.jpg
    Nov 2008
    643
    Re: Problems with cutting in corners
    I would do a test burn just before mirror 1. so just beyond the output of the tube. Burn on light wood so you can see the pattern. A good tube would show a pattern like when you burn something with a magnifying glass using the sun. Post an image of the pattern.
    Always be careful working around lasers.
  1. Replies: 1
    Last Post: 01-25-2020, 08:47 PM
  2. NOT 90 DEGRRE CORNERS IN CUTTING A SQUARE
    By gporthos in forum CNC Machining Centers
    Last Post: 11-25-2019, 08:32 PM
  3. Replies: 4
    Last Post: 03-04-2015, 11:02 AM
  4. NM200 not cutting 3-D and corners smoothly
    By JMD custom in forum Novakon
    Last Post: 03-14-2012, 07:48 AM
  5. cutting corners out
    By galaxyman7 in forum Mastercam
    Last Post: 12-11-2009, 02:33 AM
