586,384 active members*
3,643 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Squareness error compensation
Page 1 of 2 12
Results 1 to 20 of 37
    Jul 2020
    33
    Hello !
    I have a slight squareness error (too little to be worth doing mechanical adjustments...)
    I wonder if accramatic a2100 has compensation table for this error (like heidenhain does)
    (What it needs to do is move X axis while Y does a linear move)
    Where can these be found in that case?
    Cheers
    Anttoni
    Mar 2008
    285
    Re: Squareness error compensation
    Kwirk, The A2100 Control 3-Axis software does not have compensation for squareness; although the 5-Axis software with two X's, X & X' did.
    The machine bed was leveled using precision spirit levels and the leveling screws on a stable 1 foot concrete single piece floor.
    Shims were used on top of the linear way trucks if need to adjust parallelism of the top of the table while moving Y-axis.
    Normally the machine X-Y squareness was set last during the mechanical build to .0005" per 12" (0.0127mm / 304.7mm) using a precision granite square.
    The granite square was set parallel to the X-Axis Center precision T-Slot; the only one of the T-slots that is precision..
    The bolts on the Y-Axis linear trucks were not tightened and jack screws were used to adjust the squareness of the X-axis by making the side of the square
    parallel to the Y-axis. Then the Y-truck bolts were torqued to spec. Only a wreck or poor leveling would normally throw this out of whack.
    Jul 2020
    33
    Thank you for your reply
    The error i have is 0.013 for 500mm so i reckon i
    Will just let it roll for now.
    I can see a ever so slight variation on a big circle.
    Not because of backlash but of squareness .
    I have also checked this by milling a big square and flippin it and check it.
    Dec 2008
    3111
    Quote Originally Posted by Kwirk View Post
    Hang on.....
    Is your 0.013/500 result based on this method ?
    ... then your report is faulty, as this method DOUBLES the error.
    0.0065/500 is a bloody good result, maybe a little more grease on the slideway (who knows?)
    Jul 2020
    33
    Quote Originally Posted by Superman View Post
    Hang on.....
    Hello. Yea i'm aware it doubles it. So i figured the error is indeed 0 013 for 500.
    Mar 2008
    285
    Kwirk, Not sure how you checked squareness; but have you verified the Gain and Balance are both equal and correct in Both Axes and Directions?
    Jul 2020
    33
    Quote Originally Posted by gwood View Post
    Hello. I have not checked them
    But i'm very sure its angle error.
    I have had similar case where a ballbar test was made and the results were pretty much same as i got with my primitive style tests hah.
    But i will check gain and balance thank you.
    Mar 2008
    285
    Kwirk, Check the Axis Balance and Gains; if good then check the X-Z & Y-Z Spindle Tram
    See Attachments:
    Jul 2020
    33
    See Attachments:
    Thanks . Tram in Z done with 300mm testbar.
    As you guys seem to have knowledge of these.
    My machine is with servo dv5 card and a prof dp card
    Are these prof dp cards prone to fail?
    How about dv5 cards? Are dv5 cards same in a non profibus machine?
    Mar 2008
    285
    DV5 card is the same in all A2100 controls, not a high failure rate board typically, Profibus Card even lower failure.
    Why are you asking. Symptoms?
    Jul 2020
    33
    Nah. But i'm the type of guy who likes to collect spares before the parts actually fail haha. That way stuff never seems to fail haha.
    Seems though this stuff is relative easy to still find?
    Dec 2008
    3111
    At my stage of life, it's the personal RAM that's usually on the blink. Haven't found a place for the spares yet......
    Jul 2020
    33
    Born in 86 i still got alot chips to do
    Even though i wish cycle time of life was slower.
    Dec 2008
    3111
    Gawd.... I got a 1/4 century on you, still got petrol in the tank, just a little slower on acceleration. My eldest is only 4 yrs under you....
    But... the world is at your feet, let's see what the next gen brings.
    Jul 2020
    33
    Pm sent. But i doubt it got sent for some reason.
    Let me know.
    Mar 2008
    285
    Kwirk, Low Batteries on WSCPU and RTCPU boards are problems; unless the batteries are changed under power on the bench.
    The WSCPU settings are documented in the A2100 Control Reference manual; but the RTCPUs are not; some people have
    put the board on a bench with an ISA video driver board, display and AT-PS2 power supply and documented the settings.
    Normally we reflashed the RTCPU on a bench with a floppy disk program. [email protected] can do this,
    as well as Siemens Mason, OH if they still support the A2100.
    The ET200 rack has failures and is had to trouble shoot unless you have a newer IM-151 with newer diagnostic codes.
    Siemens has dropped support on some of the servo drives; which may be a problem.
    With SomocomU the parameters can be backed up from the drives.
    Jul 2020
    33
    Thanks. That it something i have read. I am in sweden so sending the boards across the sea would suck.
    I hope siemens here in europe has some sort of support.
    Im thinking of taking the boards to a computer guy who has
    Computers from nt era (made my backup hd on one).
    Meaby he can change the batteries under safe condition.
    Mar 2008
    285
    In the field I have taken the Power supply out of the A2100 control; put it on a bench, hooked up the P1 & P2 power connectors with the
    Black wires of each plug in the middle side-by-side. Used an old plug from a PC, or Video Display to power on the power supply;
    then changed the battery. I have previous posts with handouts on checking the battery on the board without losing the settings in RAM.
    Jul 2020
    33
    Cheers man.
    I will search for them.
    Great info.. really big thanks.
    Jul 2020
    33
    Another question. To be honest, i havent really looked much in to the acramatic box but it all begins to clear..i quess tthe wscpu is pretty straight forward to pop out with the power supply.
    But the Rtcpu . Where does one feed it with power when changing the battery?.
    Thanks for your time.
Page 1 of 2 12
  1. Pitch Error Compensation
    By crow36 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2022, 11:31 PM
  2. Both-direction pitch error compensation!!!
    By Rukam22 in forum Fanuc
    Last Post: 04-25-2020, 11:01 PM
  3. Error 3094 in compensation data
    By zappa42m in forum SIEMENS -> Sinumerik 840C
    Last Post: 08-10-2009, 06:14 AM
  4. Radius compensation error messages
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 05-24-2008, 10:10 PM
  5. Machine pitch error compensation
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2006, 05:52 PM
