I've just started getting my benchtop PM25 (like basic Tormach PCNC) working so am a newbie but I have some questions:
Is the most common strategy for machining both sides of a plate (0.5 x 2 x 2 inch) to clamp a small depth at the bottom, machine the top and sides, flip over and face the rest of the material then chamfer?
That would mean the sides are machined all from one side on one operation but you need a moderate amount of extra material to be able to clamp it.
What would be the minimum depth to clamp? I'm trying to make a 11mm deep part out of the 12.7mm stock that doesn't leave much.
If there is not enough material to clamp at the bottom what is the next best option? Machine ~1/2 the sides from side 1 and 2 but I expect that leaves a visible and noticeable step in the side?
