586,688 active members*
2,935 visitors online*
Results 1 to 1 of 1
    Sep 2016
    punching rubber
    Can you use a vertical cnc mill to punch holes in 3/16" thick silicone rubber by mounting a hammer driven hole punch (1/4" hole) in the spindle? Use the machine to accurately locate a pattern of holes, move to position, travel -z thru the rubber to a delrin backing plate, and repeat to the next location. Spindle is not turning, rubber is clamped to table to prevent movement. Shearing force about 130 pounds.
    Machine is a Mazak VC-EZ-20. Thanks
    Nov 2013
    4445
    Re: punching rubber
    rubber is so squishy its really hard to punch....depending on the rubber compound.
    At University to cut holes in those red rubber bungs, which is near impossible, we'd drop the bung in liquid air until it was frozen solid, and then cut it with a sharp annular tool,
    sort of like a hole saw. Provided you took it quietly and did not use to much force (and shatter the bung) it worked well. Biggest hurdle was to handle cyrogenically frozen parts,
    its real bad for your skin!!
    Craig
