586,655 active members*
2,268 visitors online*
Results 1 to 7 of 7
    Jun 2010
    7
    Invert Slave servo Y
    I am almost 3 years into build my Avid CNC pro 4" x 8" with DMM servos.
    Rack and pinion system so servos need to rotate the opposite way to move it one way.
    Almost got it running but í have the problem that the slave servo goes the wrong (right) way when I put it in Slave to Y mode.
    I cant invert the rotation because slave servo settings just follow the settings of the master servo.
    Feel pretty stupied because I can´t find anyone with the same with the same problem and this style of CNC routers is popular.
    Eding software
    Regards
    Christer
    Jun 2010
    7
    Re: Invert Slave servo Y
    I found it out.
    Very logical. Just switch DIR+ and DIR-
    Jun 2010
    7
    Quote Originally Posted by brunolundh View Post
    That was wrong, now they ONLY go way way :withstupi
    erhm... in that case.. Flip the wiring of one of the servo's?
    Jun 2010
    7
    The servos dosent work like that. The encoder flip out.
    In this case with DMM I needed to put all reference voltage in a pin on the driver
    Ok.. i admit.. i don't know anything about servo's.. but.. maybe... inverting the encoder signal in some way?..
    Nov 2013
    4443
    most modern AC servos have serial connected encoders, and it's not possible to invert it....and even if you do you have made a real cockup.
    With an inverted encoder the drive detects an error between the commanded position and the actual position (as reported by the encoder), and the drive will
    excite the servo to reduce the error.....but because the encoder is inverted the servo will go the wrong way, so the error increases, so the drive increases the excitation.....
    and the error gets even bigger.......until it crashes.
    If you invert the encoder you have to reverse the direction of the servo also otherwise you will cause the servo to 'run away' and crash. With an AC servo that requires that you swap
    two phases to the servo.
    Modern AC servos are very plainly labeled with respect to phasing and encoder polarity such that this 'run away' does not occur, you are advised to stick to it. There are better ways to do this.
    Craig
  1. Invert Jog keys?
    By HayreAss in forum Haas Mills
    Last Post: 02-17-2022, 06:03 AM
  2. Replies: 0
    Last Post: 11-27-2012, 11:45 AM
  3. Invert code
    By JW Peters in forum G-Code Programing
    Last Post: 03-09-2006, 04:06 PM
  4. How to invert slave motor direction?
    By toolbox911 in forum Stepper Motors / Drives
    Last Post: 02-14-2006, 04:16 PM
  5. Master and Slave servo
    By Builder in forum Servo Motors / Drives
    Last Post: 11-02-2004, 03:55 PM
