586,096 active members*
3,540 visitors online*
    Jun 2010
    7
    Reversed rotation
    Is it possible to change the ”default” direction the servo rotates, in the software?
    I have a servo as slave and I can’t change so master and slave rotates in different directions in the controller software. I have a rack and pinion machine and DYN4
    Regards
    Christer
    Dyb
    Re: Reversed rotation
    Quote Originally Posted by brunolundh View Post
    Regards
    Christer
    Dyb
    Normally can be set by parameters, depends on what brand servo are you using.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2010
    7
    Quote Originally Posted by cncmakers001 View Post
    Its DMM techology. With the DYN4 driver
    Nov 2013
    4375
    I use Delta servos which are very similar, and you can set the Direction pulse input active high OR active low thereby reversing the direction.
    Do you have and are you using DMM's set up and tuning software? If so it should be easy enough to find the correct parameter to adjust.
    Craig
    Jun 2010
    7
    I got answear from DMM.
    I needed to connect some pins in the SUB25 connector on the driver.
    Needed 5V in some analog reference.
    Now it works great
  1. Replies: 1
    Last Post: 03-18-2021, 06:38 PM
  2. Panasonic Minas A4 - Reverse Motion Rotation / Direction
    By Mutantmatt9000 in forum Servo Motors / Drives
    Last Post: 11-11-2016, 12:50 AM
  3. How to Reverse Rotation on Panasonic Minas?
    By parametric.ms in forum Servo Motors / Drives
    Last Post: 10-11-2009, 02:57 PM
  4. Reverse
    By frankg521 in forum Mach Mill
    Last Post: 08-06-2007, 03:08 AM
  5. Reverse?
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2006, 12:20 AM
