586,108 active members*
3,073 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > SL20 TB Hass lathe spindle overload
    Need help on our 2008 Haas SL20 TB lathe.
    The trouble all started when we changed the motor pulley.
    We were testing it at 500 rpm for a few minutes then ran it up to1500 rpm.
    A few minutes later, there was a pop and we found that the drive had failed.
    Since then,
    the drive has been repaired and tested twice,
    the motor has been cleaned,refurbished and tested
    the motor connection block has been tested and cleaned
    the motor encoder has been tested and repaired
    the Wye Delta contractors have been replaced
    the Haas tech was here 5 hours
    and still when the spindle is commanded to run 500 rpm it runs at 17 rpm
    and has a 200% power draw. HELP ! ANY IDEAS ?
    Re: SL20 TB Hass lathe spindle overload
    Quote Originally Posted by Flathead26 View Post
    Since then,
    The problem comes after changing the motor pulley, and you have tested driver and motor and even encoder.
    It seems the problem from the mechanical parts stuck, which requires bigger torque to run.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    The chuck turns freely by hand.
  1. spindle overload error bridgeport ez path sd lathe
    By buddzzeltaib in forum Bridgeport / Romi Lathes
    Last Post: 07-20-2021, 02:34 AM
  2. Haas Sl30 lathe Spindle overload
    By waznik72 in forum Haas Lathes
    Last Post: 10-05-2018, 07:10 AM
  3. Haas SL20 lathe
    By millingdale in forum Haas Mills
    Last Post: 06-08-2017, 03:05 PM
  4. HASS SL20
    By MadMan5000 in forum DNC Problems and Solutions
    Last Post: 07-13-2009, 01:10 PM
  5. HAAS SL20 Lathe
    By SGP in forum Haas Mills
    Last Post: 01-04-2007, 11:06 PM
