586,076 active members*
3,768 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Looking for master list of data fields for Haas Mill
    May 2013
    167
    I want to import data into the "Probe Type" field which is in the tool offset screen on the haas controller, but I don't know what data field name to use in my G-code.
    It's going to be looking for a numeric value ( 0,1,2 or 3 )
    Is there a master list of data fields for the haas machines?
    I'm attaching a picture of the Probe Type column I'm referring to.
    Jan 2021
    8
    Re: Looking for master list of data fields for Haas Mill
    Hope this helps
    May 2013
    167
    Thank You very much.... this will get me going in the right direction....
    Thanks again,
    Kent
    Sep 2021
    12
    One way to do this is to export your offsets to an OFS file. On newer controls, I know you can press F4 on your list programs interface to bring up system options... this includes the ability to save your offsets. I'm not sure what this looks like on older controls, but on NGC it looks like an XML file which includes all parameters for tool offsets, including Tool Name, which cannot be accessed by a macro variable.
  1. Replies: 3
    Last Post: 01-06-2020, 07:22 PM
  2. Replies: 8
    Last Post: 02-20-2017, 07:02 PM
  3. RFQ Capabilities Master List
    By Nova9911 in forum Employment Opportunity
    Last Post: 01-22-2007, 08:44 PM
