is there a company that the 3/4 shank tooling and the 1 inch tooling use the same size inserts?
There definitely should be! Just need a little more information to help answer:
-Is this for the Mill or the Lathe?
-If it is for the Lathe are you looking for Square Shank or Round Shank Tooling? Also, is it for turning, grooving or threading?
-If it is for the Mill then are you looking for indexable End Mills in 3/4" and 1" Shank?
Generally most indexable tools available on 3/4" shank is also available on 1" Shanks
Thanks!
Mike
www.toolhit.com
