586,121 active members*
3,622 visitors online*
Thread: Fanuc ext
    Feb 2018
    23
    Fanuc ext
    Hello all
    Ok, I have recently changed employment, twice. In my original job I used G54 To G59 to set the lathes I was on and in the EXT , X is Zero, and Z is Zero
    In the two new jobs, they just use work shift, GL10 P0 Z- ?????
    But in the EXT , Above G54 etc, there are values in both the X and the Z .
    Why would there be a value in the X?
    I'm in the UK so the values are mm. The X has something around 320.0
    Any ideas
    Pete
    Feb 2006
    1792
    Re: Fanuc ext
    Normally EXT should have zero values.
    However, it does not hurt it it has non-zero entries. Just make sure that these values are not changed.
