586,500 active members*
1,860 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 128 Memory Disk Format ERROR (OSP7000, LB15II)
Results 1 to 1 of 1
    Hi!
    I switched on OKUMA LB15II OSP7000 (build in 1999).
    Got this message. What is the problem? In memory board or I need to reinstall OSP.
    I tried to insert install floppy, but instalation process not started.
    Aug 2011
    419
    Re: 128 Memory Disk Format ERROR (OSP7000, LB15II)
    You must initialise CMOS memory first. Then you can install software
    Looks like I have only Bubble memory.
    I have no CMOS in my lathe
    Aug 2011
    419
    OSP7000 control units doesn't have buble memory type.
    "Imagination is more important than knowledge."
    How can I initialase CMOS?
    I did not remember such procedure in Maintenance Manuak for my LATHE
    Aug 2011
    419
    - Power off
    - Insert 1st floppy (install disk #1)
    - Power on
    - Type A;H when menu appears on screen
    Thank you!
    Tomorrow will check and replay about result.
    Sorry, not helped...
    Mar 2010
    5
    same error 128 Memory Disk Format ERROR after battery low
    when battery diskete load and try format - bus error
    how iinitialize SRAM memory?
    I am making retrofit. Bought CHINA TD1000 and 3 servo drice + servo motor. The price for all China kit was 2000 USD + 2200 USD work.
    It is more effective then try to up old machine.
