586,096 active members*
3,378 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM can't run M code in Memory mode
    Dear all.
    I have my trouble is: My CNC machine( it's using Fanuc OMC controller, with PMC axis control) can't run M-code from Memory mode, but I can let it run correctly in MDI mode.
    Does any one can guide me to fix this problem?
    Thanks for your help.
    Nam.
    Dec 2009
    953
    Re: Fanuc OM can't run M code in Memory mode
    When you press the start cycle button is that lit(green color) or is not:
    1.If start button is not lit you must check the following:
    -diagnose 122 must be XXXXX001-means machine is in auto mode
    --diagnose 120 XXXXX1XX---this bit must be 1 when you press cycle start button
    -diagnose 121 XX1XXXXX this bit ia feed hold signal
    2.If the start button of cycle start is lit wth green colour but the machine do nothing check following:
    -diagnose 700--all bits on 700 line must be 0 if everything is ok,if any bit is 1 when you press cycle start on diagnose 700 line please come back and let us know what bit
    -diagnose 701 bit 5 XX0XXXXX must be 0 in normal operation
    Please check and let us know
    Dec 2023
    4
    Quote Originally Posted by zavateandu View Post
    It seems this solution is absolutely correct. I believe it will work normally again
  1. Replies: 5
    Last Post: 11-27-2020, 05:11 PM
  2. Fanuc 16MB won't run in auto mode.
    By Rocketq in forum News Announcements
    Last Post: 02-08-2019, 02:42 PM
  3. Replies: 2
    Last Post: 07-28-2015, 05:02 AM
  4. Replies: 5
    Last Post: 05-29-2013, 07:04 PM
  5. Replies: 3
    Last Post: 07-13-2011, 02:32 PM
