Originally Posted by
steve127
I too had this problem. I called Tormach and they had a me ground my mill. Plus they said that the serial port from the back of the mill (the multi pin (11?) pins) might be to close to the frame, causing an arch, so I took a file and moved about a 1/2 inch of material off the body of the mill.
Also I had a vacum hose attached to the head of the mill to suck all the chips off the table and I think it caused ALOT of static and caused the computer to freak out. So I removed the vacum. Any way I have not had the problem since. Except when I am drilling I will get just one limit swich call, I refernce everything and then I have no more trouble. But if that is the only time I get it I am happy
Steve
