586,106 active members*
3,346 visitors online*
Results 1 to 2 of 2
    Feb 2018
    23
    G76 THREADING
    Hi everyone.
    OK, I have been programming fanuc lathes since 1988. Using the 2 line G76 for threads. I have just started with a new company and the control I'm using is a 30i on a CMZ 2 axis lathe .
    I tried programming a 16mm x 2 ext thread. But no matter what I did the first pass was at 13.7 mm. Very deep and not good. I tried starting at 24mm, 30mm etc. Still drops straight to 13.7 mm for the first cut. How does the system decide where the 1st cut begins?
    G0X20.0 Z5.0
    G76 P020060 Q010 R0.05
    G76 X13.400 Z-50.0 P1228 Q307 F2.0
    I have used the manual guide and that's OK, but why??
    Cheers all
    Pete
    Feb 2018
    23
    Re: G76 THREADING
    Sorry it is a 32i
    and I just noticed it goes below the x value straight away
    Dec 2012
    395
    Re: G76 THREADING
    Probably your first G76 line isn't okay, try;
    G76 P020060 Q100 R0.05 or G76 P020060 Q100 R50
    G76 X13.454 Z-50. P1227 Q300 F2.
    Dec 2008
    3109
    Re: G76 THREADING
    I've used a fanuc control that uses thread angle from the perpendicular of the thread axis
    (ie. choice of 0, 15, 25, 27.5, 29, & 30)
    Also try P020029 .... 29° to allow clean up on flank of thread
    Feb 2006
    1792
    Re: G76 THREADING
    Quote Originally Posted by singist48 View Post
    Hi everyone.
    G0X20.0 Z5.0
    Cheers all
    Pete
    Rough calculations:
    Core dia = 13.4
    Thread height = 1.2
    OD = 13.4 + 2x1.2 = 15.8
    First DOC = 0.3
    First roughing X = 15.8 - 2x0.3 = 15.2
    You are saying that it is 13.7
    Please check if the program is typed correctly on the machine.
    Initial X does not matter, as you have seen.
